ABS or not?
  • Piet
7 years 5 months ago #208301 by Piet
ABS or not? was created by Piet
Hi,
need to change a rear axle bearing on my Jimny from 1998. Do you know how to check if I have ABS (without stomping the brakes and see if the ABS engages)?
7 years 5 months ago #208303 by Lambert
Replied by Lambert on topic ABS or not?
Under the bonnet on the right hand side there will be a big metal block that has a load of metal brake pipes and a big electrical plug if you have abs. Also from underneath the car you will see a plastic connector on the drum back plate with a wire leading from it if you have abs. I'm not sure from when abs was on all Jimny but an early one is less likely to have it.
Time to create page: 0.067 seconds
