fluid changes capacitys gen 3 jimny
  • barnsley john
7 years 6 months ago #208142 by barnsley john
fluid changes capacitys gen 3 jimny was created by barnsley john
I all your probably sick of seeing my name by now but I am a newbie and want to learn
so having the jimny about a month now I want to look at changing most of the main fluids just to make sure its all done and peace of mind
i want to put decent oils in and make sure i have the correct grade and quantity so this is ware i need to be simple and nothing over the top
also in a list so lets have a go if I've missed anything please add to list and a difficulty in the job may be this can be helpful to other newbies
difficulty in job 1*= easy 5 * = hard job to be done oil needed grade etc quantity liters any special tools needed
make
engine oil and filter type
front diff
rear diff
transfer box
plugs
please can someone help fill this in or may have a link to these questions thanks john
  • Cremator1
7 years 6 months ago #208143 by Cremator1
Replied by Cremator1 on topic fluid changes capacitys gen 3 jimny
Hi have a look on wiki top of the page all you need is there
7 years 6 months ago #208155 by jackonlyjack
No eBay APP ID and/or Cert ID defined in Kunena configurationOnly tool you will need for changing oils
Remember to undue the fill plugs first ;)
7 years 6 months ago #208163 by Lambert
Just be aware that the manual gearbox is VERY particular about having a proper gl4 oil not one of the hybrid gl4/5 oils motor factors are want of selling.
  • Jim Jim
7 years 6 months ago #208214 by Jim Jim
Replied by Jim Jim on topic Fluid change capacities, Gen 3 Jimny
to the OP...oil and filter is very easy to change. I removed the exhaust heat shield and coolant expansion tank for easier access to the oil filter. I used 10W-40 Castrol since I am in the tropics.
Do not omit flushing coolant and brake fluid as part of the over all service....see same wiki page for specs and advice on coolant type.
Cheers.
  • barnsley john
7 years 6 months ago #208222 by barnsley john
Replied by barnsley john on topic fluid changes capacitys gen 3 jimny
I every one thanks
just read posts
wife has had me painting all week so i am on and off forum
got to keep her sweet thanks john
Time to create page: 0.149 seconds
