towing a trailer
  • barnsley john
03 May 2019 15:48 #207203 by barnsley john
towing a trailer was created by barnsley john
newbie to jimny wondering about fitting a tow bar to take my kit car for track days
so what's the jimny like at towing
my thoughts are that I want to do some track days with my Westfield kit car aprox 600kg plus trailer weight this would be instead of driving the kit car to track has it is road legal but if you brake it at track you need to get it home
so could the jimny pull a trailer with the car ok or would it be struggling
circuits are not too far away about between 35 and 70 miles from home
any body help thanks john
03 May 2019 16:05 #207204 by Lambert
Replied by Lambert on topic towing a trailer
Legally the maximum trailer weight is 1300kg so if you are able to get a trailer to carry the car that weighs less than 700 kg you're away. As for the ability to tow a Jimny is perfectly capable but is definitely going to struggle on hills. I regularly tow a twin axle sheep trailer at full weight around the Yorkshire Dales and we have plenty of steep climbs but Dreadnaught copes admirably. That being said I only got about 75 thousand miles out of the standard suspension before it was all bouncing and horrid but new stiffer dampers have made all the difference in the world. That's with a live load though, a car won't move about in the same way. Long and short of it, a Jimny is fine if you have a mind for it's lack of power and short wheelbase.
The following user(s) said Thank You: barnsley john
03 May 2019 16:10 #207205 by Lambert
Oh and not wishing to give you ideas but...
  • Foxtrot
03 May 2019 16:39 - 03 May 2019 16:44 #207209 by Foxtrot
Replied by Foxtrot on topic towing a trailer
If your trailer is unbraked then it is 350kg, I use to tow caravans with my 1300cc Jimny, the first caravan was an Eriba Puck which weighed 500kg, the Jimny dragged this ok. I upgraded to an Eriba Familia which had a MTPLM of 900kg, the engine torque was to low and I found pulling out of junctions, inclines and overtaking was uncomfortable..
I would think that your car/trailer combo would have the added benefit of been low profile and less susceptible to wind resistance.
I would be interested to see if the new 1500cc engine is better at towing?
Last edit: 03 May 2019 16:44 by Foxtrot.
Time to create page: 0.127 seconds
