Notchy gearbox. 2nd, 4th, reverse only?
  • Young Pretender
7 years 6 months ago #206626 by Young Pretender
Notchy gearbox. 2nd, 4th, reverse only? was created by Young Pretender
Hi folks
Recently replaced the clutch and had anticipated that it would resolve my notchy gbox but no. Also replaced gbox mount.
Extremely notchy gbox in 2nd, 4th and reverse only. No amount of positive shifting overcomes this, its quite bad and has got progressively worse of late. Almost as if the gear lever is flexing when shifting into those gears.
Terminal gbox or is there something simple I can check first? Was wondering whether it may just be easiest to source a used box and get that fitted rather than wasting money chasing fixes but not sure how many hours labour to replace box if anyone knows?
Any help welcome thanks
2001 jimny manual
Mark
7 years 6 months ago #206628 by Lambert
I would be wanting that either rebuilding or replacing with a good used one asap. The bearings are relatively simple to replace but the shafts they carry on are not. My research suggests that locally a rebuild is about 400 to 500 quid.
  • Young Pretender
7 years 6 months ago #206629 by Young Pretender
Replied by Young Pretender on topic Notchy gearbox. 2nd, 4th, reverse only?
Hmm thanks lambert.
Shame the car is only worth double that :)
  • Young Pretender
7 years 6 months ago #207109 by Young Pretender
Any other ideas for me guys - anyone had a similar problem?
Wondering if there are any cheap things I can try. Some decent gbox oil maybe?
Cheers
7 years 6 months ago #207110 by sniper
Post the year and model of the car, chances are that someone on the forum will be able to help with a spare box.
sniper
The following user(s) said Thank You: Young Pretender
7 years 6 months ago #207111 by ahtr
Checked the 2 rubber bushes at the back of the shifter mechanism underneath the car? Might be worth having a look at this thread and checking them... LINK
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Time to create page: 0.095 seconds
