Jimny oil changes
7 years 7 months ago #206197 by Wailin
Jimny oil changes was created by Wailin
Have my jimny 2 weeks now and did an oil and filter change, flushed and changed coolant and changed brake discs and pads. I'm guessing that previous owner never bothered with diff, manual gearbox and transfer box oil changes. Would you recommend these should be done? If so are they easy enough to do and what oil should I use?
7 years 7 months ago #206204 by BGBrit
Replied by BGBrit on topic Jimny oil changes
I would... and change every four years or so.
Front& Back Differential oil
Hypoid gear oil API GL-5
Differential oil capacity
: 1.35 litres
NOTE:
• It is highly recommended to use SAE 80W-90 viscosity.
Gear oil :
API GL-4
I used SAE 75W-90 viscosity
Oil capacity for 4WD model : 0.9 litres
Tightening torque
Oil level/filler plug (b) : 23 N•m (2.3 kg-m, 17.0 lb-ft)
The following user(s) said Thank You: Wailin
Time to create page: 0.082 seconds
