Temporary/timed warning lights on dashboard
- Keirravn
7 years 7 months ago #205366
by Keirravn
Temporary/timed warning lights on dashboard was created by Keirravn
Hey all.
In the process of fault finding behind the dash I've managed to knock out some of my warning lights. I believe I shorted them out. Engine management and oil are the obvious ones that aren't working. It's not the bulbs. Battery light and abs light still works.
Is there a relay somewhere that controls the lights that come on for a few seconds? Is it built in to the circuitry of the instrument panel?
Help appreciated
Help appreciated
7 years 7 months ago #205367
Replied by Riccy on topic Temporary/timed warning lights on dashboard
Checked all the fuses? some under the dash and some near the battery
- Keirravn
7 years 7 months ago #205370
by Keirravn
Replied by Keirravn on topic Re:Temporary/timed warning lights on dashboard
Dash fuses fine. Wouldn't have thought the fuses by the batter would impact it but I'll check to be sureRiccy wrote: Checked all the fuses? some under the dash and some near the battery
- Keirravn
7 years 7 months ago #205373
by Keirravn
Nope no underbonnet fuses relate to this
7 years 7 months ago #205374
Replied by Riccy on topic Re:Temporary/timed warning lights on dashboard
sorry for the obvious question, but it had to be asked. Check earthing and connections, otherwise its a spare part needed.
J999pre will probably have a spare dash cluster to swap in. Mileage displayed will correspond to the used part there, but it should work.
The following user(s) said Thank You: Keirravn
- Keirravn
7 years 7 months ago #205376
by Keirravn
Replied by Keirravn on topic Temporary/timed warning lights on dashboard
So do you reckon the instrument panel has internal resistors or some such which controls the temporary light up as opposed to it being a separate part or from the ECU?Riccy wrote: sorry for the obvious question, but it had to be asked. Check earthing and connections, otherwise its a spare part needed.
Time to create page: 0.098 seconds
