Engine Tuning
- Hugo
7 years 7 months ago #204950
by Hugo
Engine Tuning was created by Hugo
I have a 2001 Jimny soft top with the original 16v engine. Only had it a few weeks and have changed the cambelt and tensioner and given it a good general service including plugs. The problem is that is running a little lumpy and drinking petrol like 3.0l, I am getting no more than 27 mpg on the motorway (65mph @ 3750rpm), the engine takes 15 to 20 seconds to drop the revs back down to the idle tickover speed when pulling up at lights etc and the she coughs and splutters a little when restarting from warm. The carb side of things appears to be controlled by part e and part mechanical cable, so I guess it will need some kind of diagnostic testing if I take it to a main dealers. Does anyone have any ideas or experience they could share before I do shed out some of my hard earned? Thanks in advance,
- Max Headroom
- Banned
- Thank you received: 216
7 years 7 months ago #204982
by Max Headroom
Replied by Max Headroom on topic Engine Tuning
Hello Hugo and a BigJimny welcome to the forums.
Sorry to hear that you have some issues. I consistently get around 35 mpg with my convertible VVT and from what you describe with the rpm drop I think it is clear that you certainly have a problem of some kind.
I'm sure someone with more experience will be along soom that has some experience of these niggles, but I noticeably improved the performance of mine by fitting a K&N air filter. Is your air filter clean?
- Thank you received: 2004
7 years 7 months ago #204990
Replied by Lambert on topic Engine Tuning
Rev hang could be as simple as the throttle body needs a good cleaning. It's not unheard of for a varnish like accumulation to cause problems.
- Hugo
7 years 7 months ago #204995
by Hugo
Replied by Hugo on topic Engine Tuning
Many thanks Lambert, I’ll check the throttle body out on my Jimny.
- Hugo
7 years 7 months ago #204996
by Hugo
Thanks for the kind welcome. Yes, I have just replaced the air filter with a standard off the shelf replacement. I guess the K&N’s are available in the BigJimny online shop.
7 years 7 months ago #204998
by facade
Replied by facade on topic Engine Tuning
Unless the air filter is solid with dirt, a K&N isn't going to make much difference.
It wants the diagnostics so that you are not just throwing money at it. If you want to punt money at it (probably a 50:50 shot), change the lambda sensor at the manifold, this controls overall fuelling, and when they go out of spec. you do get rich running, and the ecu thinks everything is awesome, as the sensor reading is "correct".
If the engine temperature reads low, the ecu will run it rich as it thinks it has a cold engine.
If the EGR valve is stuck open it will cause a rough idle and affect MPG, but I'd expect the engine light to come on.
On the other hand, 27MPG into the wind at 65MPH with off-road tyres would be good for a Jimny anyway.....
