A groan from the front.
  • Don76
7 years 8 months ago #204534 by Don76
A groan from the front. was created by Don76
Hi All
Seeking some wisdom... as usual.
I hope one day I am wise enough to deliver some wisdom as well. Not yet though :laugh:
I changed my front king pins 2 weeks ago and the jimny is driving great. However, at slow speeds, below 5mph when parking etc I get a small groan from the front passenger side for the first few degrees of movement then it stops. It does this when you turn the steering wheel left or right. I can’t hear this at all when driving, that may be because of cabin noise but I can’t be sure.
It’s definitely coming from the passenger side swivel area.
Is this just a 2006 jimny having a moan and I have OCD or may there be a problem?
When I put the new king pins in, the passenger side actually felt better than the drivers side. Both sides had shims in top and bottom so I put them back as they were.
Any wisdom greatly appreciated thanks. :)
7 years 8 months ago - 7 years 8 months ago #204554 by Lambert
Replied by Lambert on topic A groan from the front.
It's not the power steering bleeding over the relief valve is it, only on full lock?
Does it do it when you have your foot on the brake? Have you checked the pads and calipers are not sticking?
Last edit: 7 years 8 months ago by Lambert.
7 years 8 months ago #204558 by sniper
Replied by sniper on topic A groan from the front.
Leave the wife at home.......
When you rebuilt it with the existing shims, you may have removed all free play but also compressed the bearing.
Shimming bearings is either a very precise and measured job OR guesswork, where you build it and check, sadly the Jimny kingpins are in the second category.
I would suggest taking a single shim out and checking the float again, it wants to be firm but not tight. You should need to use a fair force to turn the hub. There is a wiki article that gives the pull force required.
Good luck with the spanners....
sniper
7 years 8 months ago - 7 years 8 months ago #204562 by Scimike
Replied by Scimike on topic A groan from the front.
Snipers correct, the shims are added or removed to get the load on the bearings correct, measured I believe using a spring gauge. It's not just a Jimny thing, old Land Rovers are the same.
It's possible by just refitting the old shims without checking things are a little tight.
Having said that our Jimny groans first thing in the morning as I reverse out which involves a lot of steering input. Can't say I notice it at all for the rest of the day. Ours is shocks moving or suspension bushes, it's not kingpin bearings as they are on my "to do" list.
So as Lambert suggest is it something else ? Maybe worth taking the load off the front wheels and get someone to check below whilst the steering is moved to confirm 100%its source before you take it apart.
Keep smiling. :)
Last edit: 7 years 8 months ago by Scimike.
  • Don76
7 years 8 months ago #204572 by Don76
Replied by Don76 on topic A groan from the front.
Thank you all for your suggestions. When the weather breaks I will take a look. If a shim does need to come out to free it up a bit would you recommend the top or bottom one?
7 years 8 months ago #204575 by Lambert
There is nothing in it really so i would do the bottom one. It's a bit easier to get at.
Time to create page: 0.090 seconds
