No reverse lights or tail lights!
  • RiverRatJimny
06 Mar 2019 10:31 #204179 by RiverRatJimny
Replied by RiverRatJimny on topic No reverse lights or tail lights!
Yes- I've had that connector apart a few times and cleaned it- now definitely suspecting it as the root cause as the reverse lights miraculously sprang back to life last night! I might just replace it as it is full of mud- i guess any 6 pin loom connector block will work? So long as it can carry 5A+?
06 Mar 2019 19:48 - 06 Mar 2019 19:48 #204205 by Max Headroom
Sounds like you might have pinned down the problem. Mud will be full of salt and minerals and = corrosion. So I would say your decision to replace it might be a very good one!
I cant comment on which block to use but wonder if there a waterproof one available to stop this happening again?
Last edit: 06 Mar 2019 19:48 by Max Headroom.
