Wheel arch trim removal
- Don76
27 Feb 2019 22:28 #203911
by Don76
Wheel arch trim removal was created by Don76
Hello all
My passenger side exterior plastic wheel arch trim is coming away from the wing at the top. Leaving a slight gap between the seal and wing. I notice in the store that new clips can be purchased. Apologies if there is already a guide somewhere but I can’t find one. Any tips on the removal and refitting of the wheel arch trim.
Thanks in advance.
Thanks in advance.
- Thank you received: 706
27 Feb 2019 22:59 #203914
Replied by jackonlyjack on topic Wheel arch trim removal
These work just fine
www.ebay.co.uk/itm/20x-Toyota-Wheel-Arch...p2060353.m1438.l2649
There is no easy way to remove
you can just rip it off but you may damage the arch where the clips fit
I removed the inner arch cover then used pliers on the wings of the clips press and push motion
some you just have to pull the arch away nice and steady
when re fitting put the clips on the arch first then push on to the wing
Jack
Jack
The following user(s) said Thank You: Don76
28 Feb 2019 00:50 #203915
Replied by helijohn on topic Wheel arch trim removal
I am wondering if this type of tool would do the trick. I have one and use it on just about all trim clips though I have not used it on Jimny arches.
www.ebay.co.uk/itm/Trim-Clip-Pliers-Remo...wYUZcAQ49:rk:32:pf:0
I do agree that getting behind these clips and squeezing while pushing is a good approach.
- Thank you received: 2004
28 Feb 2019 05:22 #203920
Replied by Lambert on topic Wheel arch trim removal
Beat me to it. Those are great for clips but if you are against a painted surface a single layer wrap of masking tape helps prevent scratches.
28 Feb 2019 08:12 #203926
LOL
On my Mitsys there is a different system which reminds me of certain types of kitchen cupboard catches and the clips just pull away as you pull the arch away; that makes them reusable too.
Lambert wrote: Beat me to it. .
LOL
- Don76
01 Mar 2019 22:55 #204001
by Don76
Replied by Don76 on topic Wheel arch trim removal
Thanks for the tips.
Time to create page: 0.094 seconds
