oh bug**r 4wd!
7 years 9 months ago #202927
by Fossie
oh bug**r 4wd! was created by Fossie
We Collected the 2nd Jimny yesterday ...a cabrio jobbie 03 plate . Drove home 50 odd miles no real issues .
Today after the off road test .....just a really really potholed muddy unadopted road to the stables we tried the 4wd ..no real discernible clunk like the other one and after a minute or so the green 4wd light came on flashing , this I read indicates vacuum issue, oh seemed to work at vendors , oh bug**r! However the machine did drag its self out of the mire as though 4wd was engaged .....went back in again in 2wd and the wheels did spin, so reengaged 4 seemed to work!
A dig around at home seems the the drivers side swivel seal is leaking , could this be connected?
Questions ...how easy will it be to find the vacuum leak , as in are there obvious places to check? Swivel seals reasonably easy to do,specific tools?
( other faults came to light while digging about but not that major.....yet!)
- Thank you received: 2004
7 years 9 months ago #202967
Replied by Lambert on topic oh bug**r 4wd!
If the swivel is wet with oil and grease it's because of dead kingpin bearings killing the axle oil seal. It's a very common problem with vas5 amounts of information in these pages.
7 years 9 months ago #202977
by Busta
Replied by Busta on topic oh bug**r 4wd!
Sounds like a small vacuum leak somewhere. Check all the obvious spots- wheel bearings first, then along the vacuum lines for leaks. Remove the hubs and check the sliding collar moves freely.
The following user(s) said Thank You: Fossie
7 years 8 months ago - 7 years 8 months ago #203437
by kirkynut
Replied by kirkynut on topic oh bug**r 4wd!
Get the leak you have found fixed. Likely to be kingpin bearings and ruined oil seal as a result.
Then buy manual free wheeling hubs from Jimny Bits and bin the vacuum hubs. Trying to keep them working will drive you to distraction.
Last edit: 7 years 8 months ago by kirkynut.
Time to create page: 0.111 seconds
