Wheel Nuts
- Thank you received: 2004
7 years 9 months ago #203022
Replied by Lambert on topic Wheel Nuts
Without measuring it with a digital caliper for your actual car I can't be absolutely certain one way or another, like I said I'm not sure if Suzuki used the same length wheel studs on all years and models to say definitely yes or no.
- Thank you received: 706
7 years 9 months ago #203024
Replied by jackonlyjack on topic Wheel Nuts
60 degree sweep is correct only jakkata wheels have the strange nut
Mickt are you swapping from alloys to steels
If yes the essayist way to see if your captive nuts will work
Is remove a wheel and screw a nut onto the stud if it goes all the way down
with lets say 1-1.5 mm gap it will hold your steel wheel fine
7 years 9 months ago #203031
Replied by yakuza on topic Wheel Nuts
My steel wheel nuts has a shorter cone than the alloy nuts. So my steel wheel nuts should not be used.
But yours might be long enough.
7 years 9 months ago #203087
by kirkynut
Replied by kirkynut on topic Wheel Nuts
I've never had an issue with capped nuts on standard studs.
I've got longer studs on the front, so I've had to buy open nuts.
Time to create page: 0.099 seconds
