Do Jimnys use oil?
  • Den1
10 Feb 2019 13:33 #202900 by Den1
Do Jimnys use oil? was created by Den1
Downloaded the Jimny manual and in the maintance section it said an oils useable of 1ltr per 1000 miles is normal?
Do these engines use oil?
Thanks
10 Feb 2019 13:56 #202901 by jackonlyjack
The following user(s) said Thank You: Den1
10 Feb 2019 16:17 #202907 by Busta
Replied by Busta on topic Do Jimnys use oil?
Having owned 3 with over 100,000 miles on them I'd say no, they don't use much oil. I don't recall ever having to top one up between oil changes, which is probably inline with Jack's 500ml in a year.
I suspect that wording is put in the manual as an indication of the point at which oil consumption through engine wear is likely to become problematic but these engines exhibit very few signs of wear, even at very high mileages.
10 Feb 2019 18:40 #202920 by Scimike
Replied by Scimike on topic Do Jimnys use oil?
I would also say no from my experience. Mine never moves on the dipstick between services, M13A VVT.
10 Feb 2019 23:09 #202951 by Max Headroom
Replied by Max Headroom on topic Do Jimnys use oil?
I'm running a M13A VVT and haven't had to top mine up since its last service almost a year ago - its used as my daily drive to work and I've done many other much longer journeys in it too
13 Feb 2019 09:54 #203096 by kirkynut
Replied by kirkynut on topic Do Jimnys use oil?
Mine does 3k miles a year or less, sometimes as little as 1700 but don't see any usage.
Time to create page: 0.101 seconds
