Throwing belts!
02 Feb 2019 08:10 #202339 by Max Headroom
Replied by Max Headroom on topic Throwing belts!
Do you have prroof that the alternator was in fact cx'd? I ask because my neighbours Jimny belts started screaming like a banshee. She had them cx'd by a local garage and all seemed well... until a few days later on a cold rainy morning with lots of current being drawn from the alternator (wipers; lights; heater fan etc) and it was shreiking again - it was also burning the belts - you could smell it.
In this instance it turned out to be the alternator - once it was on demand it was trying to stop the engine!. She Cx'd the alternator and the banshee impersonation vanished in an instant
However as previously mentioned it could also be the water pump.
02 Feb 2019 08:42 #202344 by Scimike
Replied by Scimike on topic Throwing belts!
That's interesting.
Can I ask how the pulley fails and on which engine configuration, M13AA Pas Air etc.
Always a day to learn something new and if I know how it fails can visually check at service.
  • WeeJim
02 Feb 2019 09:07 #202345 by WeeJim
Replied by WeeJim on topic Throwing belts!
Thanks one and all.
It's an M13. No aircon. The £120 was essentially for two hours labour as they took the radiator out. They checked all the pulleys, which were apparently fine.
I'll get it to another local guy over the weekend and mention the crankshaft pulley and see how we go.
Typical that it happens with two inches of snow on the ground. Driving in a blizzard last night was no fun.
Uptake once it running.
02 Feb 2019 09:20 #202346 by Lambert
Replied by Lambert on topic Throwing belts!
The crank pulley is a two part bonded type that doubles as a harmonic balancer. The bond is a rubber thing much like a very thin metalastic bush in the suspension. Over time the bond fails causing the driving elements to become misaligned under load from the tension of the belts and to then oscillate when rotating which destroys the belts in short order. The bolt that holds the pulley to the crank is a large flanged thing that readily corrodes to the pulley making it a potential nightmare to get undone, even with impact guns. It's not a difficult job if it goes well but can easily be a complete pig.
02 Feb 2019 09:37 #202347 by mlines
Replied by mlines on topic Re:Throwing belts!
I wouldn't take a visual inspection of the pulley as being ok
It's a two part pulley with a rubber separator. The rubber wears and fractures but still just hangs on.
See the thin rubber band in the picture.
02 Feb 2019 10:22 #202348 by facade
Replied by facade on topic Throwing belts!
Lambert wrote: The bolt that holds the pulley to the crank is a large flanged thing that readily corrodes to the pulley making it a potential nightmare to get undone, even with impact guns. It's not a difficult job if it goes well but can easily be a complete pig.
As in my case. (I have a long thread on it, but it would put you off doing it)
However, it is really easy if you simply cut the flange off, which would have saved me many hours of messing about for the cost of a new flanged bolt in the beginning.
Time to create page: 0.113 seconds
