410 transfer box
- Amarok88
31 Jan 2019 23:18 #202228
by Amarok88
410 transfer box was created by Amarok88
Hi guys,
Planning on running 235/75/15 on my jimny.
Got the chance of a 410 transfer box for £80. Should I go for this or save up the 700 for rock lobster and cradle.
If 410 is it a straight swap or do i need other bits?
- Max Headroom
- Banned
- Thank you received: 216
31 Jan 2019 23:24 #202230
by Max Headroom
Replied by Max Headroom on topic 410 transfer box
Hello Amarok and a BigJimny welcome to you from the Cotswold Hills.
I can't answer your questions but I'm sure someone will be along very soon that can.
- Thank you received: 2004
01 Feb 2019 05:27 #202243
Replied by Lambert on topic 410 transfer box
The 410 is a direct ish swap. You will need different propshafts as the bolt holes are different and one of the shafts is too long. Have a quick search and all the specific requirements are on here.
Welcome to the forum.
01 Feb 2019 07:07 #202249
by kirkynut
Replied by kirkynut on topic 410 transfer box
You'll need a Rocklobster. Only get it from Richard Wattam (Rockwatt) and discuss all new gears or polished gears to keep the noise down.
01 Feb 2019 07:26 - 01 Feb 2019 11:06 #202251
Replied by yakuza on topic 410 transfer box
Hi Amarok88
The 410 box is half of what you need for a Rock lobster if you like to get one made from your own parts. You take some parts from a SJ410 and some from a SJ413 box, combine, machine and weld (precision skilled work!).
The outside of the SJ box does not change so it is the same adaptation needed to fit a rocklobster to a Jimny as a 410 transfer. You will need the cradle and the driveshafts depending on what model your Jimny is.
EDIT: Correction! A 410 box might have smaller flanges that will not add up to the later driveshafts on Samurai and Jimny.
For me I even had a rocklobster case on my shelf, but i still found it was too much work/cost to put it in my 2005 Jimny.
I rather bought low gears for my Jimny transfer case.
See grimjeeper gear calculator to check different gearing choices and tire size.
Last edit: 01 Feb 2019 11:06 by yakuza.
01 Feb 2019 07:28 #202252
Best option in my opinion is to buy the ready made low gear sets and put them in a 413 box and make your own rocklobster. SJ transfer boxes are very easy to work with.
Or change the gears in your Jimny transfere if your Jimny is 2005 or later.
Time to create page: 0.105 seconds
