Rolled my Jimny
- gundog48
7 years 9 months ago #202133
by gundog48
Now you might be wondering how I got here.
Ice, a hill, an oncoming car, bad driving. Ouch. She deserved better.
Managed to get her upright and she made it to work and back again, there was a bit of oil that had drained into the air filter, but once that was cleared up the engine ran just fine. She feels a bit funny, I think probably because of the damaged bodywork the sound and feel is different. Of biggest concern to me is the fact that, when changing gears, the positions feel a little shifted to the right. Apart from that, there's no sign that anything is actually wrong.
Apart from the body that is. Windscreen is cracked and will need replacing, driver's wing mirror completely crushed, driver's door deformed, driver's pillar dented and scraped heavily. Assuming there is no damage to the engine or any of the other moving parts, I see 3 options:
I'd be interested to know where I could look for replacement parts for a proper repair. I can see the door being fairly straighforward, but I've no idea about the pillar. The door just about opens and closes, locks, and the window shuts if you give it a push, but when you open the door past about 30 degrees it starts creaking and has to be forced.
I've always liked the idea of doing some modding ever since I got it- I'm a good welder and fabricator, but have limited knowledge on how that applies to vehicles. In my head I'm seeing the doors removed and a canvas top and a roll cage. More sensibly it'd probably be some body filler, paint and a snorkel to cover it all!
I guess my question is, if this was yours, what would you do? What advice can you give to me? Thanks in advance!
Rolled my Jimny was created by gundog48
- Repair it- a full repair will be costly, but I can make it driveable for less than £200
- Embrace it- if it's not going to look like new again, maybe some creative modding and painting can embrace the look
- Sell it- Probably worth a few hundred quid to someone I can put towards something new
7 years 9 months ago - 7 years 9 months ago #202134
by Busta
Replied by Busta on topic Rolled my Jimny
Last edit: 7 years 9 months ago by Busta.
- Thank you received: 706
7 years 9 months ago - 7 years 9 months ago #202135
Replied by jackonlyjack on topic Rolled my Jimny
Firstly you're ok that's the first plus point
sorry for your Jim
I would give it a good check over before spending anything
looking at chassis axles steering parts panhard rods (for bends.twists'cracks ect)
buy a second hand door new windscreen take a hammer to parts straiten them best you can filler and snorkel like you said
maybe a fancy paint job your choice of pattern
and just embrace what damage is left (will make for conversation)
Jack
Edit: door looks ok
sorry for your Jim
Jack
Edit: door looks ok
Last edit: 7 years 9 months ago by jackonlyjack.
- Max Headroom
- Banned
- Thank you received: 216
7 years 9 months ago #202143
by Max Headroom
Replied by Max Headroom on topic Rolled my Jimny
Hi Gundog
Really sorry to learn of this mishap. Good job that you are ok though but it puts a downer on everything a bit.
Like Jack says, it might be worth investigating what damage has actually been done before parting company with your hard-earned beer-chits.
Being a body on chassis construction it could be possible to re-body the vehicle - this is something done in the vintage car world without so much as a raised eybrow - but on the JimnyI understand its rather more involved and complex - and then there's the overriding question of would it be worth it?
7 years 9 months ago - 7 years 9 months ago #202146
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Rolled my Jimny
Glad you are OK, must have shaken you up!
Most things can be fixed.
Fortunately, Jimny's are relatively light and I think pretty strong, so aside for some denting, you may well have got away without too much major damage.
If it was me I would consider fixing it up. Door and mirror off a breaker. New windscreen, tidy up the pillar. Filler and paint or even some wrap, maybe a snorkel. Will be good as new before you know it. As already mentioned have a good look around - maybe use a tape measure/straight edge to check things aren't bent or twisted.
If it helps. 2 years back I got caught between a Volvo estate and a ford transit in my trusty old VW golf TDI that I had paid £550 for 12 months prior. Volvo clipped me from the right and shoved me to the left into a Transit. Right and left wings stuffed in, bumper pulled half off, smashed headlight and some broken clips and mounts for the bumper and a stretched track rod. When we checked the tracking the next day it was 1cm out on the driver's side. Looked worse than it was. Made a hole in the wing and the bumper with a screwdriver and hammer, then a couple of cable ties to get the bumper secured and drove sedately for the 50 miles home. Happened at 6pm on a Monday night. I ordered the parts mainly off breakers on ebay that night and the following day a couple of cheap wings off Euro Car parts. Had it all back together by Friday evening and the new wings early the following week after getting them sprayed by a pal of mine. Cost me about £175.
Last edit: 7 years 9 months ago by adrianr.
- Thank you received: 2004
7 years 9 months ago #202156
Replied by Lambert on topic Rolled my Jimny
Glad you are ok. It looks fairly repairable but I wouldn't be happy with it until I had had it on a jig to be absolutely clear that it was just cosmetic damage even then I would be essentially rebuilding the car with new bushes and joints and everything else I wasn't totally happy with. But equally I would leave as much of the body damage as I could that didn't impair the functionality of the car. Good luck.
Time to create page: 0.099 seconds
