Propshaft on Jimnybits
  • BerntS
7 years 9 months ago - 7 years 9 months ago #201954 by BerntS
Propshaft on Jimnybits was created by BerntS
Hello
I broke the old one on my 2004 Jimny
I run the sj transfer and a 2 inch lift
I see on jimnybits that they come in two sizes 80 and 85cm
When I messure flange too flange the old prop is 71cm
I recommend that i need the 80cm but can you experts cofiirm?
Last edit: 7 years 9 months ago by BerntS.
7 years 9 months ago #201979 by Lambert
Replied by Lambert on topic Propshaft on Jimnybits
Is that between the transfer box and axle or between the ends of the existing propshaft taken off the car?
The following user(s) said Thank You: BerntS
  • BerntS
7 years 9 months ago #201995 by BerntS
Replied by BerntS on topic Propshaft on Jimnybits
The 71cm is with the propshaf is mounted on the car.
So between the transferbox flange and the diff flange :-)
Bad english but i hope yoy undestand.
7 years 9 months ago #201997 by yakuza
Replied by yakuza on topic Propshaft on Jimnybits
I got lots of SJ shafts if you need something Bernt..
The ones with slack has been recycled already so joints are ok on these.
Guessing the slip yoke short part is the same on all..
  • BerntS
7 years 9 months ago #201998 by BerntS
Thank you Yakuza :-)
But i think it will be Jimnybits for this one :-)
7 years 9 months ago #201999 by yakuza
rear or front by the way?
You will need the front Samurai drive shaft?
And something special rear?
And does your rocklobster box have the 8mm or 10mm holes in the flanges??
Time to create page: 0.096 seconds
