Re:torque settings for engine swap m16a
  • invincible
7 years 9 months ago #201865 by invincible
torque settings for engine swap m16a was created by invincible
hey there everyone , i think i may have found a donor engine m16a , and i might get a m13a too to swap the parts over so jimny isnt off the road as long, tell me if this is stupid idea! i did see on here somewhere but cant find again , where the torque setting for all the swap parts were emailed by PM , please can anyone help if they have them, cheers in advance. L
7 years 9 months ago #201884 by Lambert
I don't have the torque specs but I'm with you on having a donor 1.3 to minimise the down time of the swap, it also has the benefit of a full set of ancillaries to go into stores for if and when they are needed.
7 years 9 months ago #201899 by yakuza
I did not use a torque wrench at all when i did my swap.
Cannot recommend that of course, but if you are well experienced in doing mods and other mechanics you could do this by feel like I did.
To move stuff over from the 1.3 just takes a few hours max so i wouldn't bother with the extra 1.3 engine. I did however prepare the 1.6 in advance before starting on the car. Removed the bottom, removed wiring, manifolds, cooling pipe and everything to be switched over.
Too much space lost in my garage for the one surplus 1.3 already :)
7 years 9 months ago #201915 by Busta
yakuza wrote: I did not use a torque wrench at all when i did my swap.
Me neither. It's only a few ancillaries that need swapping over. There are no torque-critical components like bearing caps or cylinder heads.
  • invincible
7 years 9 months ago #201964 by invincible
Replied by invincible on topic torque settings for engine swap m16a
ok , sound , cheers guys, stupid question but the donor engine will need its 1.6 injectors left in yes, ive seen one but look like they have been removed. you dont swap over the 1.3 ones?
7 years 9 months ago #202032 by ahtr
Yes, use the 1.6 injectors
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
