Squeaky wipers- pivot bush worn.
- Max Headroom
- Banned
- Thank you received: 216
Theyre pricey but once I started using them on other cars I've owned they were so effective I now put them on everything; they do seem to make a big difference and certainly cured the issues I had with the Jimny. If you are refreshing your wiper system they could be worth considering if you haven't already got them.
(I've tried the Valeo ones - they're good too and a bit cheaper, but dont last as long)
- Thank you received: 2004
Works OK and not too much play and slack yet to change it, but sometime...
Bought the wole mechanism on my 2006 VW T5 just to change the motor.
Suprised that it wasn't too expensive brand new, hoping that is the case for the Suzuki one as well.
The Bosch ones do not work on cars with more curved windshields and/or in colder weather. Have been working good until now on my Jimny but the cold weather makes them too stiff so they do not touch the surface except here and there. not a streak in them when it is more than +1C but I will have to change them for the stiffness and not because they are worn so to say...Max Headroom wrote: Busta when I first got my Jimny (last Feb/March) I had terrible wiper blade squealing and juddering - this is probably not the same issue as you have as you mention you think yours is a worn bush - but the whole wiper blade issues that I did have vanished the moment I fitted those Bosch flat-blade jobs.
And on my VW i only use the original ones. Bosch is awful on that car but works ok on the Jimny.
- OlaGB
Is that the aerotwin ones? I have the Biltema clearview on mine, and they freeze up _very_ quick when it snows. Was planning to buy the aerotwin`s, but youre comment made me rethink that now..
