Stick change 4WD system - dashboard lights
14 Jan 2019 20:55 #200753 by PHB1969
Hi - I’m looking for a Jimny and have driven a 4 so far - one stick change with no 4wd lights at all, 2 with audible hub engagement and green 4wd light when in 4wd H and one push button selector which wouldn’t go into 4wd L from 4wd H.
My question is should there be a change in dashboard lights for a stick selector model when going from 4wd H to 4wd L please?
Many thanks
Paul
14 Jan 2019 23:08 #200763 by Busta
No. The 4wd light will come on when you select 4H and stays on when you select 4L. There is no separate light to indicate low range.
15 Jan 2019 05:04 #200772 by Lambert
When you were testing out the push button one did you have your foot on the brake and the clutch fully disengaged when you tried for 4lo?
15 Jan 2019 17:58 #200809 by PHB1969
Tbh, I can’t remember. I asked the seller how it should engage and he didn’t know, so almost think he knew it was problematic.
15 Jan 2019 17:59 #200810 by PHB1969
Busta wrote: No. The 4wd light will come on when you select 4H and stays on when you select 4L. There is no separate light to indicate low range.
Thank you for confirming
Time to create page: 0.094 seconds
