Removing vacuum system
- RogersJimmy
7 years 10 months ago #200627
by RogersJimmy
Removing vacuum system was created by RogersJimmy
From my earlier posts you will see that the vacuum system is not functioning on my 2001 model (4WD lever on floor), so I am seriously considering some manaul FWH from Jimnybits at £114.99 all in. The car is completely standard and is only used for road work and the occasional muddy field.
I see from the very useful wiki guide that the vacuum system can either be blocked (to fool the controller) or removed and the 2 wires bridged on the controller socket.
My question is: is there any reason why I cannot disconnect the intake manifold pipe and block the manifold stub off, and then bridge the 2 wires?? Seems quite the easiest way to me, but have I missed something?
7 years 10 months ago #200628
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Removing vacuum system
That makes sense to me. Would be easy to reverse if it throws up a fault so if it was me I would give it a try.
The following user(s) said Thank You: RogersJimmy
7 years 10 months ago #200668
by ahtr
I've done exactly this. Fitted AVM hubs. Removed the whole vac system including hoses and steel pipes on the axles. Put some silicone caps on the hubs and inlet manifold. Removed the 4wd controller under the dash and linked the two blue cables on the plug to keep the 4wd light working.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Replied by ahtr on topic Removing vacuum system
RogersJimmy wrote: My question is: is there any reason why I cannot disconnect the intake manifold pipe and block the manifold stub off, and then bridge the 2 wires?? Seems quite the easiest way to me, but have I missed something?
7 years 10 months ago #200674
Replied by yakuza on topic Removing vacuum system
So many of these threads that says to remove the system i was wondering why no one says to just fix the leaks or the system?
I would just like to balance it and give other possibilities
7 years 10 months ago #200683
by Scimike
Replied by Scimike on topic Removing vacuum system
For balance I intend to keep my system as switch operated from the comfort of my seat.
The vacuum pipes are rusting up and I intend to replicate them using brake pipe, I will make templete from them so I can bend the pipes in the same profile. The only issues is the system is still working fine and I will only tackle this when I have a fault to fix.
Maybe thats the issue, most are still working..
- RogersJimmy
7 years 10 months ago #200718
by RogersJimmy
Replied by RogersJimmy on topic Removing vacuum system
Hi yakusa, I would fix the system if I could. Trouble is, I can’t find the reason for lack of vacuum despite working through the wiki tutorial.
It is most likely a leak from a pinhole in one of the rusty metal pipes, but how do you find it without renewing each in turn? It’s not like an air pressure leak that you might find with soapy water.
So my new manual FWHs arrive on Wednesday and then all will be fine!
Time to create page: 0.095 seconds
