Which gearbox/rear engine mount?
- Jimx5
27 Dec 2018 23:28 #199516
by Jimx5
Which gearbox/rear engine mount? was created by Jimx5
I had the MOT done this morning and while the car was up in the air i asked how bad the rear engine/gearbox mount was and as i expected it was very soft, and as i have had difficulties selecting 1st and reverse when cold this could be the culprit and needs sorting any way.
I have searched the forum store which threw up 2 mounts one with captive nuts and one without, so rather than getting back under the car tomorrow does any body know which mount i need for an 04 Jimny Mode.
Many thanks, Dave.
Many thanks, Dave.
- Max Headroom
- Banned
- Thank you received: 217
28 Dec 2018 01:07 - 28 Dec 2018 01:08 #199520
by Max Headroom
Replied by Max Headroom on topic Which gearbox/rear engine mount?
Dave do a search in the forum over the past 8 months or so...
Unless I've confused this with something else Im thinking of, I'm sure someone here has mentioned a BMC Mini rubber mount can be used for this - cheap as chips in Halfords, apparently.
Last edit: 28 Dec 2018 01:08 by Max Headroom.
The following user(s) said Thank You: Jimx5
- Jimx5
28 Dec 2018 04:53 #199524
by Jimx5
Replied by Jimx5 on topic Which gearbox/rear engine mount?
Yes i half remember that posting, but for the life of me i can't find it, plus the postings only go back a month or so.
28 Dec 2018 07:58 #199529
by Busta
Replied by Busta on topic Which gearbox/rear engine mount?
Max, I suspect you are confusing the rear engine mount with the transfer case mounts. The mini mounts would work ok on the transfer case, although they wouldn't be as strong or flexible as the genuine items. The rear engine mount is a more complicated design and only a genuine mount will work.
Jim, I can't advise which you need as I only ever thought there was one type!
The following user(s) said Thank You: Max Headroom
- Thank you received: 1852
28 Dec 2018 08:07 #199530
Replied by Lambert on topic Which gearbox/rear engine mount?
The mini bushes are for the gear lever assembly. The captive and none captive type mounts are supposed to be interchangeable but I would inspect the existing again and get the same type.
- Thank you received: 673
28 Dec 2018 09:03 #199532
Replied by jackonlyjack on topic Which gearbox/rear engine mount?
My 04 has the captive nut type
Yes the mini bobbins x2 fit on the gear stick remote assembly
It made a big difference on gear selection when i fitted the bobbins
