Passed MOT - few technical questions
- Leighlo
09 Dec 2018 21:09 #198820
by Leighlo
Passed MOT - few technical questions was created by Leighlo
My 2008 Jimny passed its MOT, I was really worried as I’ve not owned the car long. Wondered if somebody could help with the advisories though?
1. Hesdlamp adjustment dash roller moves in bulb up and one bulb down! (I knew this and always found it a bit quirky!)
2. Rear shocks need replacing soon. Should I go for Suzuki OEM?
- Thank you received: 2004
10 Dec 2018 05:07 #198824
Replied by Lambert on topic Passed MOT - few technical questions
1 sounds like the polarity of one of the motor connections has been inverted?
2 depending on how you use the Jimny there are a number of alternatives for replacement dampers but for just pottering about oem aren't a bad compromise for durability and serviceability if a little expensive.
- Max Headroom
- Banned
- Thank you received: 216
10 Dec 2018 08:34 - 10 Dec 2018 08:35 #198829
by Max Headroom
Replied by Max Headroom on topic Passed MOT - few technical questions
Leighlo, I can't comment on the headlamp issue as I wouldn't have a clue but Lambert's theory sounds logical to me.
On the subject of the rear shocks, I got a pair of Monroe Adventure Dampers on the strength of someone else's recommendation. While I haven't fitted mine yet, the other member said he was very pleased and that they transformed his car. They're competitively priced and the seller ( atp-spareparts ) is the same seller I got mine from, neither I, nor the other BigJimny member had any problems.
Hope this helps.
Hope this helps.
Last edit: 10 Dec 2018 08:35 by Max Headroom.
10 Dec 2018 09:25 #198830
by Busta
Replied by Busta on topic Passed MOT - few technical questions
I fitted Monroe dampers and I can confirm they are definitely much better than the worn out dampers they replaced.
- paradox1001
10 Dec 2018 09:53 #198833
by paradox1001
Replied by paradox1001 on topic Re:Passed MOT - few technical questions
I’ve monroe dampers fitted aswell
- Leighlo
10 Dec 2018 18:54 #198857
by Leighlo
Replied by Leighlo on topic Passed MOT - few technical questions
Thanks! I’ll take a look!
I’m just glad it passed. MOT time is always such a nervous time!
Time to create page: 0.103 seconds
