engine swap m16a vvt
  • invincible
7 years 11 months ago #198520 by invincible
engine swap m16a vvt was created by invincible
hey chaps, ive read as much as i could fine about jimny engine options, and am i right in understanding that a suzuki swift 1.6 engine,
M16A VVT will nearly be a straight swap for my existing M13A VVT engine, apart from some parts swapping, like sump , oil filter thread and the ecu should be ok being a vvt engine originally. thought better ask before i go spend £700 on a lump to fit. cheers.L
  • OlaGB
7 years 11 months ago #198531 by OlaGB
Replied by OlaGB on topic engine swap m16a vvt
Correct! Ive done it myself, 07 swift sport motor in a 05/06 jimny. Some pictures in my build thread in my signature.
But ensure you buy a motor older than 2010, as they got a new crank/cam sensor system in 2010/2011, that the Jimny ECU can not work with.
And if you got the money, i believe a dyno tune would be benefical to get the most out of the swap, allthough you dont have to.
I havent done it (yet), but i am considering it. I am conviced theres more power to be had, not just max power but also a stronger low/mid range.
You will be told it`s not possible by some people, but i`ve spoken to 2 companies than say the jimny ECU now can be remapped using K-tag ecu tool.
  • invincible
7 years 11 months ago #198752 by invincible
Replied by invincible on topic engine swap m16a vvt
Cheers olagb, good advice info, does 300cc make much difference though for time and money? what bhp and torque is new engine?
Cheers liam.
7 years 11 months ago #198755 by ahtr
Replied by ahtr on topic engine swap m16a vvt
invincible wrote: Cheers olagb, good advice info, does 300cc make much difference though for time and money? what bhp and torque is new engine?
Cheers liam.
I've put an m16a in mine (but not VVT) and the extra cc's make a load of difference, it's a much better drive. I expect with the extra poke of the VVT it'll be even better. Going up steep hills where I'd usually be flogging it in 2nd gear, it just cruises up in 3rd without any fuss now.
I know there's a couple of people on here who've swapped the VVT engine so one of them might be able to help you out with more details of the swap. But swapping the earlier M16a was straightforward.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
7 years 11 months ago #198772 by yakuza
Replied by yakuza on topic engine swap m16a vvt
Cheers liam.
It's the same job with the VVT, no extra sensors or wires. But you have to swap a VVT for a VVT.
It is easier with the Liana engines as all the sensors are the same. You will have to swap to a period correct engine to keep it hassle free.
Mine is a Liana. Higher compression is the only difference.
  • invincible
7 years 11 months ago #198801 by invincible
Thanks guys ill start digging deep on research and hunting for an engine flea bay will be the place eh? it will be a change not being blown near still driving over the a66 in wind!
Time to create page: 0.089 seconds
