reversing lights
22 Nov 2018 13:34 #197990 by maverick
Replied by maverick on topic reversing lights
gerbox switch failure i suspect - they are cheap to replace
Jalapeño, IISY?
  • invincible
22 Nov 2018 13:56 #197993 by invincible
Replied by invincible on topic reversing lights
i cant find any fuse numbers in the manual or on the cabin fuse box cover just amp rating of fuses? cant see written on it reverse lights
is there defo a fuse for reverse light i,m well stumped!! pic of cover below.
  • invincible
22 Nov 2018 14:05 #197994 by invincible
took gearbox switch out in the summer and tested it it worked fine but when back in the gearbox it wouldnt so i cut the wire ran it into the cabin and put a switch on it.
i must have left it on and its burn a wire out somewhere on the way the the rear.
looks like i,ll have to run other wires and have a spot light then. bugger!
22 Nov 2018 15:27 #198005 by facade
Replied by facade on topic reversing lights
invincible wrote: i cant find any fuse numbers in the manual or on the cabin fuse box cover just amp rating of fuses? cant see written on it reverse lights
I went on the wiring diagram for the numbers.It will be the one labelled BACK on the lid ;)
(Back up lamp is Foreign Speak for reverse lights)
  • invincible
22 Nov 2018 15:39 #198007 by invincible
mega thanks mate i,ll go look now. fingers crossed
  • invincible
22 Nov 2018 19:01 #198022 by invincible
hey facade youre a wizard!! pulled fuse YES it was blown the BACK fuse as you said. changed it put my switch on tried it still no reverse light, and checked fuse and its blown again! i was thinking its just a switch as on gearbox or does it need earthing is the only thing i can think of?? humm
Time to create page: 0.109 seconds
