Fitting rear bearings and collars
- S200KYS
19 Nov 2018 20:17 #197813
by S200KYS
Fitting rear bearings and collars was created by S200KYS
Everytime I've done the rear wheel bearings on S200KYS I've taken the shafts round to my local garage and paid them to fit the new bearings for me, presuming they had the required press to do it. Getting friendly with the two guys that run the garage they said surely I could do my own bearings, to which I said I didn't have a press, and that's when they told me how they do mine..
A suitable length of seamless pipe - 19" and 29" I used, although the longer one would do both shafts - and a lump hammer!
The bearing and collar are a tolerance fit and 'just' need knocking onto the shafts... I started with the smaller shaft and did the bearing on it's own until it was nearly home, and then the retaining collar afterwards... But on the longer one I did them together which seemed no more effort but saved hitting the bearing directly with the pipe.
Not too bad a job
Note the stout block of wood with stout battens on top arranged so that the wheel studs weren't in contact.
Satisfying to do-it-yourself, and saved a few quid too :woohoo:
Not too bad a job
- Thank you received: 2004
20 Nov 2018 05:22 #197827
Replied by Lambert on topic Fitting rear bearings and collars
Interesting. I have a press in the event of doing mine but good to know its not absolutely necessary.
20 Nov 2018 10:20 #197839
Replied by yakuza on topic Fitting rear bearings and collars
I heated the retainer in the oven..
Baked them at 150 degrees for an hour.
Also just used a pipe to knock them on.
Didn't bother driving 5 minutes to a press i can use.
- S200KYS
20 Nov 2018 10:52 #197840
by S200KYS
Replied by S200KYS on topic Fitting rear bearings and collars
I considered that (heating the retainer in the oven) but was (unnecessarily?) worried about heat transferring to the bearing?...
- Thank you received: 706
20 Nov 2018 11:01 #197841
Replied by jackonlyjack on topic Fitting rear bearings and collars
This is good info but whats best way to remove them :huh:
Grinder/slitting disc ??
20 Nov 2018 16:44 #197853
by Busta
Replied by Busta on topic Fitting rear bearings and collars
Nice solution. It's not a job I've ever had to do on the Jimny, but faced with that problem I would tap it on with a punch, moving about 1/3 of the way around the bearing with each tap so it went on evenly. If using a pipe make sure the end is cut perfectly square or, better still, rotate it a bit with each hit.
Time to create page: 0.109 seconds
