Half shaft removal
07 Nov 2018 19:15 #197437
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Half shaft removal was created by HUN
Hello Ladies&Gents.
Do I need to drain the oil from differentials before attempting to remove half shafts? I was thinking to place some shims or change kingpin bearings to cure a little death wobble but I'm not keen to drain oil again as it's been recently changed. Any advice much appreciated. Thanks.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- Thank you received: 706
07 Nov 2018 19:28 #197438
Replied by jackonlyjack on topic Half shaft removal
just jack up and place axle stand under the side you intend to work on
leave for a short time and the oil will run down hill
worked fine for me
worked fine for me
- mickt
07 Nov 2018 19:45 #197439
by mickt
Replied by mickt on topic Half shaft removal
As long as you drain the oil into a clean container you could reuse it no bother.
07 Nov 2018 22:05 #197441
by kirkynut
Replied by kirkynut on topic Half shaft removal
As above regarding jacking one side up, this sends the oil to the other side.
However, why not just whip a king pin out without stripping the front axle down? Pop a shim on it and pop it back in.
No need to worry then. Just put a little instant gasket on it.
Time to create page: 0.081 seconds
