Brake disc dimensions
28 Oct 2018 00:16 #197116
Brake disc dimensions was created by yakuza
I have ordered brake discs now two times, and both times recieved 107mm center hole discs. These are SJ dimensions. Or does some jimnys use that?
My 05 with ABS is 108mm center hole.
Last order mishap was my own fault not checking dim properly.
28 Oct 2018 02:56 #197117
by gv42
Replied by gv42 on topic Brake disc dimensions
hi,,euro car parts do a 107,, and a 108.3,,, too.
- Thank you received: 2004
28 Oct 2018 06:41 #197120
Replied by Lambert on topic Brake disc dimensions
I think but am not sure that the 107 was pre 2004 and 108.3 was post. I think.
- Max Headroom
- Banned
- Thank you received: 216
28 Oct 2018 08:55 - 28 Oct 2018 08:56 #197121
by Max Headroom
Replied by Max Headroom on topic Brake disc dimensions
If you go on the Halfrauds site and and search for the brake disc there using your registration number, it should tell you the size for your car. (I did this for mine and received the correct discs).
(Note: I only used Halfrauds as I have a trade card, and it made a very significant difference to the price
- I actually don't care for Halfrauds that much but they have their uses :evil: )
Last edit: 28 Oct 2018 08:56 by Max Headroom.
28 Oct 2018 10:20 #197122
Replied by yakuza on topic Brake disc dimensions
I think so too Lambert, either pre/post '04 or ABS/non-ABS ( wich may even coincide. )
I have looked on several sites and it varies on most even if I use the license plate numbers. I have tried other numbers a s well both '99 , my own '05 and the only diesel in Norway. No pattem on it. most seller offer both 107, 108 and even both vented and non vented..
Anywas i know what i need, a vented disc with 108 center so if i only check it properly before ordering i should get what i want
- S200KYS
29 Oct 2018 06:37 - 29 Oct 2018 06:39 #197141
by S200KYS
Replied by S200KYS on topic Brake disc dimensions
All the info' is in the BigJimny store -
www.bigjimny.com/store/brake-disc-suzuki-jimny-107mm.html
www.bigjimny.com/store/brake-disc-suzuki-jimny-108-3mm.html
Vehicles up to VIN 203804 require 107mm centre discs
Vehicles from VIN 203804 require 108.3 mm centre discs
Last edit: 29 Oct 2018 06:39 by S200KYS.
Time to create page: 0.106 seconds
