Knocking noise coming from transfer case?
- roscoepcoltrane
18 Oct 2018 15:01 - 18 Oct 2018 15:02 #196857
by roscoepcoltrane
Knocking noise coming from transfer case? was created by roscoepcoltrane
Hi there, I've got a loud knocking noise coming from my transfer case when any load is put through it. I originally thought it might have been a UJ or a duff shaft, but after swapping out the rear prop shaft with another one i had, and taking off the front driveshaft altogether it still makes the noise - There's a lot of play where the rear shaft goes into the transfer case, so my guess is the bearings have blown and the case has eaten itself to pieces? Any advice would be greatly appreciated:)
Last edit: 18 Oct 2018 15:02 by roscoepcoltrane.
18 Oct 2018 17:25 #196858
Replied by Riccy on topic Knocking noise coming from transfer case?
Either t-box bearings as you say, or maybe a broken mount or bracket perhaps?
possibly the gearbox rear mount has delaminated. test it by getting under and pushing the gearbox. if it goes up, the mount is broken.
18 Oct 2018 18:55 #196860
by Busta
Replied by Busta on topic Knocking noise coming from transfer case?
It sounds to me like the chain has stretched. If so, swap the whole box out. It's not worth trying to repair.
18 Oct 2018 21:50 #196864
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Knocking noise coming from transfer case?
I've updated transfer brackets for sale and a couple of second hand push button transfer boxes of you need anything
Grey pick up Jimny
Time to create page: 0.079 seconds
