Indicators are Switching on Hazard Lights
  • Pkayman82
10 Oct 2018 18:17 #196641 by Pkayman82
Hello,
My Jimney is Switching on the Hazard lights when I indicate left or right.
I tried disconnecting the Hazard light switch but made no difference.
What could be the problem???
10 Oct 2018 18:25 #196642 by Busta
Do you have a tow bar with a trailer socket wired up? If so, start looking there.
  • Pkayman82
10 Oct 2018 19:02 #196643 by Pkayman82
Replied by Pkayman82 on topic Indicators are Switching on Hazard Lights
I do have a trailer socket wired up. Ill have a look at that some day and see if it can be sorted from there.
Thanks
  • helijohn
10 Oct 2018 19:18 #196645 by helijohn
Replied by helijohn on topic Indicators are Switching on Hazard Lights
Busta wrote: Do you have a tow bar with a trailer socket wired up? If so, start looking there.
Would that not have been doing this from the installation?
11 Oct 2018 04:15 #196647 by Lambert
Towing electrics are notoriously fragile being exposed to the elements behind a useless plastic flap, water and muck soon get in and then you have the green death in the wires. Hateful things.
  • helijohn
11 Oct 2018 06:48 #196651 by helijohn
Lambert wrote: Towing electrics are notoriously fragile being exposed to the elements behind a useless plastic flap, water and muck soon get in and then you have the green death in the wires. Hateful things.
Yes, been there and got the T shirt. I had a trailer board that the wire had run along the ground and I only knew about it when it was a dying battery. It is the reason I have voltmeters in every motor.
Time to create page: 0.116 seconds
