Snorkel template
  • Probablynotfrank
03 Oct 2018 16:02 #196476 by Probablynotfrank
Snorkel template was created by Probablynotfrank
I'm new, so this is my first post! Was wondering if anyone had a template for the long jimny bits snorkel and would be willing to send me it? Bought a second hand snorkel for cheap, just no template.
04 Oct 2018 04:05 #196486 by Lambert
Replied by Lambert on topic Snorkel template
Be aware that some people have used the provided template and it hasn't been perfectly accurate. Making one with some card from the actual snorkel isn't difficult if you have the skills to attempt fitting a snorkel yourself.
  • Probablynotfrank
04 Oct 2018 07:57 #196491 by Probablynotfrank
Replied by Probablynotfrank on topic Snorkel template
I just need to know where the hole for the snorkel goes as it's a solid bit of Plastic into the air box, and I'd presume it has to be quite accurate? The rest of the holes for bolts I could figure out
04 Oct 2018 14:55 #196495 by jackonlyjack
Replied by jackonlyjack on topic Snorkel template
remove inner arch liner take the part off the inner wing that connects to air box
take out air filter roll up some card push it from air box out to the wing use a scribe/marker pen
where your rolled up tube touches the wing best guess at central point or remove wing to make pilot hole
then use a hole saw
Time to create page: 0.111 seconds
