stiff gear lever
8 years 2 months ago #196009 by safari
stiff gear lever was created by safari
I have a problem with the gearlever while in traffic it is getting stiff to change gears . What can the problem be hope not to change gearbox
any help pls
if u worry u die if u dont worry u still die so why worry
  • TomDK
8 years 2 months ago #196013 by TomDK
Replied by TomDK on topic stiff gear lever
Have you checked oil?
8 years 2 months ago #196018 by ahtr
Replied by ahtr on topic stiff gear lever
As above, worth checking the gearbox oil level. And while you're under the car check the gearbox/rear engine mount and the 2 rubber bushes at the back of the shifter mechanism. Mine were ruined, replaced them all and shifts a lot smoother now.
Have a look at this thread, worth doing for the small cost.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Time to create page: 0.085 seconds
