Transfer box options
- Thank you received: 305
Whilst in 4H, on pressing the 4L button with the car in neutral and the clutch depressed, I can hear the transfer box try to engage but I just get a continually flashing 4L light and a matching beep. This eventually times out and the indicators go back to 4H.
Jackonlyjack popped round and we changed the oil as I feared it had been flooded, all was clear and good. wiring looked ok.
Do I spend money getting a transmission shop to sort it or should I swap to an earlier stick shift transfer box ?
What is needed to fit ?
Your advice/suggestions would be gratefully received.......
sniper
I think if you change to lever operated transfer box you would have to change your gearbox also. Unless there is a special part (I'm not aware of) wich mates the old transferbox with new gearbox? Others might confirm my theory.
Regards, Gabor
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
- Thank you received: 706
Jack
- OlaGB
sniper wrote: My push button transfer box is refusing to go into 4L, it goes into 4H and as far as I can tell, all is ok.
sniper
I believe the pushbutton box has stronger chain in it, than the stick type. And the gear ratio are different, so a stick transfer change would be best to combine with a older gearbox as well. Consider youre diff ratio too..
Most likely youre issue is either the shift motor or even more likely, a position sensor (4wd low switch). Shouldnt be to hard to troubleshoot.
Check this out:
www.trail-gear.com/PDF/304505-3-INS.pdf
