How strong is the back axle
- Thank you received: 2004
17 Aug 2018 10:09 #195196
How strong is the back axle was created by Lambert
Hi all. I have been doing maths. By my reckoning a standard Jimny in low first sends a maximum of 975 nm to the rear diff. My proposed engine and gearbox are going to send approximately 1012nm in the same direction. As it an automatic box even with a lockup clutch it's not going to be as brutal as a manual. Second I'm going to be running a smaller wheel and tyre combination to rein in the theoretical top speed which is going to see an 8pc drop in diameter.
Initially I was thinking of Toyota axles but I don't want it to look odd and I want to keep the weight off.
Will a Jimny axle cope? I know that stronger internals are available but are they really necessary?
17 Aug 2018 10:33 #195197
by facade
Replied by facade on topic How strong is the back axle
It is less than 4% more, I can't see that being a problem.
The diff is a 4 pin, which is fairly strong, usually people twist the halfshafts and snap the short one, when they have very grippy tyres, before the diff bursts.
There has been some discussion on here about the auto box being at its limit with the standard engine, I'd be more worried about this..
17 Aug 2018 11:19 #195198
Replied by Lambert on topic How strong is the back axle
Ah no the box will come with the 1uzfe and drive straight to the diff so it's only the axle that is going to be struggling if at all.
17 Aug 2018 12:26 #195208
by Busta
Replied by Busta on topic How strong is the back axle
What about the fact that the diff is offset? For narrow axles that can handle the power and have a diff in the right place look at older Volvos. Many of them have Dana axles.
17 Aug 2018 13:50 #195209
Ok cheers. Thing is though a propshaft doesn't know or really care what angle it runs at so long as the mounting faces are parallel.
- TomDK
17 Aug 2018 19:41 #195213
by TomDK
Replied by TomDK on topic How strong is the back axle
Time to create page: 0.091 seconds
