Another question....about brakes!
  • Basketcase
16 Aug 2018 21:41 #195186 by Basketcase
Another question....about brakes! was created by Basketcase
My Jim went for mot few days ago and well it was horrific... the brakes had little or no pressure on the rear but front passed ok...it’s had (I believe) 3” springs 2” spring spacers and 2” body lift...it’s not got load valve corrector thingy...would that make the brakes not work at the rear? The handbrake doesn’t even work could it just be air trapped inside the load compensator valve? Or something else? I’ve checked the shoes they look fine enough meat on then for it to still work to some extent more than it does! My old Jim had less meat and stopped far far better...any idea guys? Also is there anyone near St. Helens that could lend me their headlights u till I get enough money to get a new set as mine have no beam pattern??
17 Aug 2018 07:40 #195188 by Lambert
Sounds like an adjustment of the shoes is needed. There's a little oblong hole with a grommet that you remove from the back plate that allows you to use a flat screwdriver to adjust the starwheel in the shoes with the wheels in place. Quite simple and should get you stopping again.
  • Basketcase
17 Aug 2018 08:30 #195192 by Basketcase
Replied by Basketcase on topic Another question....about brakes!
I’ve tried that and the handbrake cable is also as tight as it can go on the handbrake lever too and that’s still pointing at the sky! Lol
17 Aug 2018 08:37 #195193 by Lambert
Snapped handbrake cable or cables? Clogged rear brake flex hose. It's just that no handbrake and no rear service brake sounds like unadjusted shoes. What does the brake pedal feel like, is it good and firm?
  • Basketcase
17 Aug 2018 08:47 #195194 by Basketcase
The cables are new from James about 2month a go, I’ve currently got the rear flexi pipe clamped off as when it’s not it really struggles to stop. The pedal goes right to the floor even with handbrake fully pulled up! I’ve just spoke to the mot tester and he said the front brakes were fine and passed it was just the pedal travel and rear brakes that failed it. I’ve bled all them up but could the re be some air left in the compensator? That was being a right pain when bleeding up?
17 Aug 2018 09:33 #195195 by Lambert
Ah ok. You found the bleeder on the compensating valve? I have abs but my last bleed took 3 goes to get it completely free of air. It goes without saying that you shouldn't have to clamp a line to get a pedal.
Time to create page: 0.109 seconds
