What else does the ecu do?
14 Aug 2018 11:24 #195118 by Lambert
Thing are getting a bit serious in the new engine installation project. I have actually started buying components, I must be mad!
Question. Is the ecu just an engine controller or does it get extra duty with things like srs airbags and abs? I'm fairly sure the abs is separate which is good as i would like to keep it but as I am going analogue with the new engine think carbs, electronic dizzy, an oil pressure light and a temperature guage I'm wondering what else can go in the bin as being undesirable weight? Think full rally car interior with the minimum of guages on a folded alloy plate type arrangement simple robust and fixed with nothing more than a Swiss army knife.
14 Aug 2018 15:55 #195129 by Jezz
Replied by Jezz on topic What else does the ecu do?
My ecu also makes the tea, and sometimes brings the jaffa cakes. ( other small orangy chocolate cakes are availiable) :whistle:
It's been fettled just a tad.
15 Aug 2018 04:44 #195132 by mlines
It also interacts with the immobiliser so you would either need that all wired in or go for an after market ECU like megasquirt
15 Aug 2018 06:19 #195133 by Lambert
After further information the initial plan has been modified slightly and while I still intend on the bare minimum of instruments I'm being forced into needing an ecu anyway so it may yet be that a fully bespoke system is employed instead of corruption of the existing. Bit disappointed to have to give up on carbs. Cheers Martin.
15 Aug 2018 08:32 #195136 by Busta
Replied by Busta on topic What else does the ecu do?
I was going to say, how are you going to get around the MOT emissions test running carbs? There's no chance of legitimately doing that on something as new as a Jimny. Throttle bodies with an aftermarket ECU is the way to do it and, cost aside, has many advantages over carbs. I don't know for fact, but I very much doubt the ECU would control the air bags. With an aftermarket ECU you should be able to ditch the standard ECU altogether.
What engine are you going for? Going this route there are lots to choose from!
15 Aug 2018 09:44 - 15 Aug 2018 09:46 #195137 by yakuza
Replied by yakuza on topic What else does the ecu do?
ECU is paired to the immobilizer antenna but the key itself (its immo-chip) can be programmed to fit if it is from the same series. The ECU also does the diagnoses and you will get a heap of error codes if you use the wrong one. There are also differences in the programming between manual and auto gearboxes. There are signals coming from the ABS to the ECU, not sure if there is any the other way but there must be some kind of speed feedback i guess. On newer models there are also more interface between the ECU and the cluster, speedo and so on.
It's a maze..
or amaze..
not sure.
When i don't understand it, I just admire it. :)
Last edit: 15 Aug 2018 09:46 by yakuza.
Time to create page: 0.103 seconds
