Engine overheating & losing coolant
  • Mithrass
08 Aug 2018 19:14 - 09 Aug 2018 08:18 #194921 by Mithrass
Engine overheating & losing coolant was created by Mithrass
Hi guys,
I'm hoping one of you experts can help a strictly amateur mechanic to fix his Jimny.
I have a 2003 O2 convertible - for fun, off-road and for my son to use when he is home. It has the G13BB engine - 1298 SOHC. Recently it began to overheat and lose coolant. The radiator was full of mayonnaise. I immediately thought the cylinder head gasket had failed so, rushing in, I took it off. (A lot of cursing and improvising special tools, but ok for a guy who last took a car apart 30 years ago.)
Having finally got to the gasket, I could find no sign of leakage through it. I'm posting some pictures. All comments and advice are welcome.
This is the head as removed, with the gasket still in place. https://ibb.co/eVstT9
This is the head with the gasket off and turned over. https://ibb.co/dSNtT9
This is the top of the block with the head removed. https://ibb.co/nC4MgU
The only clue I could see was one of the cylinder head bolts was heavily coated with a carbon deposit. https://ibb.co/byTggU
Here's a closeup of the corner where the bolt came from. https://ibb.co/jofSMU
Does this mean anything to anyone? All advice gratefully received.
The images are attached in order. I can't find a way to make them appear in the text.
Last edit: 09 Aug 2018 08:18 by Mithrass. Reason: Correct an image URL and add attachments
  • X8GGY
08 Aug 2018 22:06 #194925 by X8GGY
Replied by X8GGY on topic Engine overheating & losing coolant
Difficult to see your photos from that post...
Here you go, for others to see -
This is the head with the gasket off and turned over.(same link as above photo?)
  • Mithrass
09 Aug 2018 07:51 #194932 by Mithrass
Replied by Mithrass on topic Engine overheating & losing coolant
Thanks for that - it's very helpful to see the images. I was expecting live links inserted in the text but it didn't work. I see I copied the wrong URL into one of the images too.
I'll see if I can edit the original post.
09 Aug 2018 09:20 #194938 by Lambert
Looking on the picture without the head gasket there do appear to be a couple of unsealed section on the right hand cylinder. Did you get the compression tested before you removed the head?
The following user(s) said Thank You: Mithrass
11 Aug 2018 21:00 #195037 by kirkynut
Well you've taken the head off now so get it skimmed just enough to ensure it's flat and put it back on with a new gasket and head bolts.
Then you'll know if it was the issue for sure.
  • mickt
12 Aug 2018 17:11 #195052 by mickt
Replied by mickt on topic Engine overheating & losing coolant
When you took the bolts off did they all seem to be the same torque?
Time to create page: 0.105 seconds
