Any help would be great!
- domdjr
Firstly my apologies if this is in the wrong topic!
I have just bought my first Jimny and I am keen to get going with installing some accessories! (I have all sorts of crazy ideas at the moment but am taking it one step at a time). My first question really is where is the best place to get wiring from the dashboard with switches etc, to the engine bay for connection, or if there are any spare looms anywhere for accessories! I was thinking about getting some spotlights on as a first port of call hence the query about switches etc!
My second question is where you find the best point to jack and put axle stands as I am looking to tidy up the wheel arches so would need to get the wheels off to get access.
Sorry if I have made no sense whatsoever and thank you for your help in advance!
- jim
On the trailing arms there's a small nipple like protrusion. I use a trolley jack on there.
Take care working underneath your car
domdjr wrote: Hi,
I do not remember where i got the wires thru, but that would indicate that i did not have much trouble finding a spot. on the side of the rubber at the big loom if you run only one or two, and maybe behind the glove compartment? You can easily unhook the upper part of the glove box and swing the glove box down for easier access. In most cases it is easier behind there as there is much more stuff in the way on the drivers side.
Axle stands can be put under the axles (
When i did my lift kit i put the stands under the main frame rails.
Always use good solid axle stands placed on an even surface if you plan to crawl under!
- domdjr
