HELP - code 0120 or maybe gear?
  • moomoo84
20 Jul 2018 08:22 #194495 by moomoo84
HELP - code 0120 or maybe gear? was created by moomoo84
Hi,
Really need your help ..
jimny 2007, Auto,
It all started with the noise of the engine rings, in the RPM medium (probably a detonation). A weak or strong press on the pedal has suppressed the noises.
An "infusion" was also made to the carburetor and K44 was inserted into the fuel tank. did not help.
After a while, when the noise disappeared, I had an engine light, with a P0120 problem code that had problems with the gear - it did not go into fourth gear or I could not do a "kick".
Replaced the TPS sensor but did not solve the problem. The bulb usually lights up when traveling between cities.
Turns off at unclear times.
Really do not know what to do .. I will be happy for any advice or idea ..
Thanks!
  • mickt
23 Jul 2018 11:27 #194556 by mickt
Replied by mickt on topic HELP - code 0120 or maybe gear?
Check your fuel supplier as it seems the fuel octane rating might be compromised(adding water maybe) What do you mean by a "kick"?
Time to create page: 0.069 seconds
