Progressive Springs
8 years 4 months ago #194406
by safari
if u worry u die if u dont worry u still die so why worry
progressive springs was created by safari
hi just fitted a set of these progressive springs they looked quite good and a bit expensive but ,when fitted them my jimny leaned to the drivers side and when i am in it it leans much more i used to have jimny bits 3" never had so much lean . has anybody fitted something similar the seller is saying they do not lean that much but from mine they do . or what shall i do before go for spring spacer ?
8 years 4 months ago #194408
by sniper
Replied by sniper on topic progressive springs
The only thing I can suggest is swapping the rear springs left to right and seeing if that has any impact, some springs for the UK are 10mm shorter on the offside to allow for the camber on the roads. If yours are and you've fitted them on wrong sides, that would explain excessive lean, maybe...
If that doesn't work, fit a single spring seat on the low side. Superpro make them in 5mm 15mm 25mm and bigger.
I considered progressive springs and decided against them, I couldn't find any on the market at the time and would have had to have bespoke springs turned. An unknown, so I stayed with standard. They weren't expensive, around £200 for the set.
The main problem was the light weight of the body and the large axle weight, trying to stop rebound being the issue.
I'd love to know how you get on with both the leaning issue and also, how the springs behave in use, a small review would be great.
sniper
sniper
8 years 4 months ago #194412
Replied by Riccy on topic Re:progressive springs
Have a look at zanfi springs. I use +3” diesel ones. Very pleased with them
7 years 7 months ago #205512
by safari
Replied by safari on topic progressive springs
Very disappointed with these springs .for the lean i had to make 2.5 spacer
For offroad not stable at all it wobbles a lot .in my last competition i was going to topple a couple of times
I have to buy new springs now
7 years 7 months ago #205519
All 4 of mine have snapped since Christmas, needless to say I’m now not impressed with them either!
Replaced with jimnybits ones and all is well now.
safari wrote: Very disappointed with these springs .for the lean i had to make 2.5 spacer
7 years 7 months ago #205562
by sniper
Bad news Safari and yours Riccy, buying what you perceive to be "high quality" because of a suppliers name and cost, yet you get poor quality rubbish.
I've gone to Eibach but at only +30mm with 15mm spacers, just to stay with a "proper" spring manufacturer.
Some lifted cars that I've seen, have literally wobbled on their springs and look weak off road because of them, big swings as the point of balance changes over a crest. Never seen them take a car over but they make the car look far less stable to drive.
Nice to see a Jimny in competition.
sniper
sniper
Time to create page: 0.101 seconds
