Broken wire and ABS light.
- 1066Boy
17 Jul 2018 17:00 #194395
by 1066Boy
Broken wire and ABS light. was created by 1066Boy
At the weekend i got hooked up in the undergrowth and snapped a wire under the car running to the rear. The ABS light has come on so by amazing powers of deduction i guess this is the wire from the sensor on the rear wheel.
Is it something special or can i just rejoin it either directly or adding a extra bit of cable? Regards Allan.
17 Jul 2018 17:20 #194397
Replied by Riccy on topic Broken wire and ABS light.
I would try and solder/heatshrink the join before buying a new sensor (which is the alternative).
I think the system relies on a specific resistance value, so adding additional cable would not be advised. The join may be enough to upset it.
Rhinoman is the electrical expert i believe, maybe send a PM?
- X8GGY
18 Jul 2018 09:12 #194415
Replied by X8GGY on topic Broken wire and ABS light.
James 'J999PRE' on here as probably got one...?
- Thank you received: 115
18 Jul 2018 12:54 #194418
by maverick
Jalapeño, IISY?
Replied by maverick on topic Broken wire and ABS light.
YES, I got a pair from James (J999PRE)
Jalapeño, IISY?
Time to create page: 0.094 seconds
