Rear Springs
  • morgan
17 Jul 2018 14:04 #194386 by morgan
Rear Springs was created by morgan
hi im new boy here .....i seem to have a problem with my rear end leaning to pass. side and gap between tyre and wheel arch less on that side . i have been told that different springs have been fitted does anyone know what color s should be on springs mine are purple and blue ....thanks for any input
john
17 Jul 2018 16:16 #194392 by Riccy
Replied by Riccy on topic Rear Springs
Swap them around, that should sort it out...
easy job, just need to disconnect the shocks at one end, then jack up the chassis. They literally fall out then ;-)
Check your not stretching brake lines or abs cables tho while jacking up. Worth checking the spring seats (rubber cone things at top of spring). You can get spacers to make up height differences as needed.
Time to create page: 0.066 seconds
