Swivel ball replacement
  • dumb_dom
19 Jun 2018 16:33 - 19 Jun 2018 16:35 #193619 by dumb_dom
Swivel ball replacement was created by dumb_dom
I replaced my kingpin bearings around six months ago, and they have went on one side already, when taking apart I’ve noticed this lip on the swivel ball where the bearings go has been cracked almost all off and the bearing was no longer a nice round shape as if it has been crushed, I don’t know what could have caused this as this isn’t a jimny used for anything but smooth tarmac roads....well uk roads.
Anyways my question is can you buy the swivel ball separate or is it a hole new axle job?
P.s. photo is just a google image for an idea of what I’m taking about
Last edit: 19 Jun 2018 16:35 by dumb_dom.
19 Jun 2018 16:58 #193623 by Riccy
Replied by Riccy on topic Swivel ball replacement
Its a complete new axle casing, the swivels are welded onto the casing.
which bit has gone/cracked off? tha actual ball part or the bit around the bearings?
  • dumb_dom
19 Jun 2018 17:03 #193624 by dumb_dom
Replied by dumb_dom on topic Swivel ball replacement
The little bit of lip around the bearings if that makes any sense. And that sucks
  • TomDK
19 Jun 2018 17:10 #193626 by TomDK
Replied by TomDK on topic Swivel ball replacement
Are you referring to the bearing race?
There's no lip around the bearing.
  • dumb_dom
19 Jun 2018 17:15 #193628 by dumb_dom
Sorry I can’t get a picture of mine as it’s at the garage on my friends lift, this is the bit I’m referring to, I’m unsure what it’s called
19 Jun 2018 17:21 - 19 Jun 2018 17:25 #193630 by Riccy
The chrome part is where the bearing sits and should be replaced whenever the bearings are changed (they come with the bearing usually).
See the Wiki guide here... bigjimny.com/mediawiki/index.php?title=King_pin_bearing_change
p.s. as Tom says, thats called the 'bearing race'
Last edit: 19 Jun 2018 17:25 by Riccy. Reason: forgot something
The following user(s) said Thank You: dumb_dom
Time to create page: 0.116 seconds
