Steering dampener kit
- ewanwells
01 Jun 2018 08:47 #193116
by ewanwells
Steering dampener kit was created by ewanwells
I've almost installed this dampener kit to my jimny. Problem is I've now come to try to tighten the nut on the rod end of the piston but it all just spins meaning I can't actually get the nut to tighten on more than a few threads.
Is there an easy way to do this... Given up trying now as I haven't been able to sort it at all...
Sent from my SM-G950F using Tapatalk
01 Jun 2018 09:46 #193117
by sniper
Replied by sniper on topic Steering dampener kit
If you look at the end of the damper shaft that the nut is on, you will see that is flat on two sides.
Put a ring spanner (ratchet ring if you've got one) on the nut and hold the shaft with a small adjustable across the flat faces, it will nip up but it's a nyloc so will be tight all the way.
It might be easier to take the mount off the bar (U bolts out), tighten the nut in question and then re-fit the mount.
sniper
sniper
The following user(s) said Thank You: Toka
01 Jun 2018 19:02 #193128
Replied by Riccy on topic Steering dampener kit
as above, its the same as shock. Just grip the flattened sides of the threaded stud with grips or spanner and tighten the (stiff) locknut.
That looks like a return-to-centre damper/spring kit. Where did you get this kit from out of interest?
- Toka
02 Jun 2018 06:52 #193141
by Toka
Replied by Toka on topic Steering dampener kit
Cheers guys, managed it now and all done...
Time to create page: 0.078 seconds
