AVM Locking wheel hubs
- kayjay
28 May 2018 15:41 #192995
by kayjay
AVM Locking wheel hubs was created by kayjay
After my winter blues with 4WD not engaging in very cold conditions I bought some AVM457 locking wheel hubs for my 2006 Jimny. I came to fit them today and there is a problem. As I tighten up the flange bolts on the hub body (wheel off the ground) the body binds locking the wheel solid, even before fitting the cover assembly. Has anyone got experience with these or can offer advice.
Thanks
Thanks
- Thank you received: 2004
28 May 2018 17:13 #192997
Replied by Lambert on topic AVM Locking wheel hubs
Err that shouldn't be possible. You're using the bolts that came with the hubs?
- kayjay
28 May 2018 17:21 #192998
by kayjay
Replied by kayjay on topic AVM Locking wheel hubs
Yes I'm using the bolts and the (strange) locking collets that came with the hubs.
28 May 2018 18:39 #193001
All I can think of is that they are for an sj not a Jimny and are touching the vacuum retention flange on the hub nut.
- kayjay
28 May 2018 18:51 #193003
by kayjay
It's very hard to determine what's binding as it only happens as I start to tighten the bolts, finger tight is OK but 10ft/lb and starts to bind, rock solid at 20+. I wonder if there is some critical dimension to measure to be sure
- Thank you received: 227
29 May 2018 02:17 #193012
by zukebob
Replied by zukebob on topic AVM Locking wheel hubs
I have the AVM457 for my Jimny also. Like Lambert, I am somewhat stumped by what you are describing. I had no such issue with mine. If someone doesn't beat me to the answer, I may try to carefully pull one of mine and see if I can replicate the problem. If I can't, I would fall back on one of Lambert's other comments and suggest that they aren't actually AVM457, even if they are in that box.
Time to create page: 0.103 seconds
