Steering box play -is it a common problem?
25 May 2018 06:57 #192931 by yakuza
I have adjusted it to try to reduce the play, but i still think the play just comes back after a while.
Adjusting too tight will make it snag in the full right/left position so there is a limit to the adjusting.
Many others that also have too much play on the steering wheel?
Mine has 100000km on it.
25 May 2018 09:42 #192936 by sniper
There is some play in mine at similar milage to yours Yakuza, I have decided to buy a recon steering box. It's more of an annoyance and doesn't interfere with safe use, so it's a way down the list of things to do. Lots of points for wear in the arms/rods too so I'll be changing the lot over time.
I have never tried to improve a box and rod steering system, never rallied a truck but plenty do. The best way I suppose is hydraulic.
sniper
26 May 2018 13:34 #192960 by kirkynut
Steering boxes will always have some play but they can be adjusted usually. Replacing it is not usually necessary. If it were a Land Rover I'd say differently!
  • Mole
18 Oct 2018 12:34 #196855 by Mole
I have a fair bit of play in mine it's done 87000 and was going to adjust the steering box what's the best way to not over do it.?
18 Oct 2018 18:58 #196861 by Busta
Slacken the nut and tighten the threaded rod a little at a time, turning the wheels from lock to lock each time until if starts to feel a little stiff at full lock. That's how I did it anyway. It took out most of the play around straight ahead.
  • Mole
18 Oct 2018 19:25 #196862 by Mole
Thanks had a play with it early and think iv sorted it
Time to create page: 0.095 seconds
