Wheels/Tyres Sorry!!!!!!!
- Dizzy37
1 I have 3 spoke alloys on my jimny at present sporting 205/70R 1596H road tyres (sorry don't know what this means google has not been my friend in this instance) the tyres on the Vitara wheels were a 195/R15 940.01S. The fitter said that the 205 were a lower profile even though the number is higher????? I want All terrain tyres I think as I want to use this for daily use as well as green laning (newby and need to start somewhere.). So what size am I looking for and what is most suitable as the tyre fitter will source the tyres if I can give him the size.
2 Wheel nuts do I need to change them to fit the steel rims?.
3 Do I need wheel spacers?
4 As I've only ever bought tyres that are listed in the manual how do I work out tyre pressures?
Thanks in advance
Diane.
If it is a standard car with no suspension modifications, I would suggest 215/75 x 15 as far as size goes.
No need for spacers.
I run AT's but do a fair few road miles and wanted the best I could get on wet tarmac (the only time I ever have a car get out of shape) and went for BF Goodrich All Terrain KO2. They are fantastic on and off road, unbelievably good in snow but expensive at £115 per corner.
Others will have to comment on different brands, there are other good ones about....
sniper
1.205 is the width(mm) 70 is the height (profile) as a percentage of the width, and 15 is the rim diameter. when there is no number between 195 and the R15 it means they are 80 profile. they are legal/equal to the original tires. As i have not seen your steel wheels it is hard to tell if they are original vitara wheels, but i guess they are, and you can most likely use them as is.Dizzy37 wrote: I have been lucky enough to barter for some 15" steel rims and they were off a Vitara they are at the mo being refinished. I tried talking to the local tyre fitter but he wasn't any help unfortunately so I'm going to ask some really stupid to you questions but can't find the answers and what I can find don't make a great deal of sense to me.
Thanks in advance
Diane.
2. again not knowing what nuts you have, or what steel wheels, but most likely you can use the same nuts. I have allways done so on my suzukis.
3. I do not recommend them, and in my country they are illegal actually.
4. trial and error for tyre pressure. For larger tyres, I have used a bit lower pressure. If your tyres are within 5% of the original ones i do not think there is no need to deviate from the original pressure. depends also if you carry alot of luggage or passengers in wich case it can be raised a bit.
I tend to use less pressure than most people but rarely go on a highway. For offroading 0.4 bar.
- 1066Boy
