Removing the steering wheel
8 years 6 months ago #192474
by Bosanek
Removing the steering wheel was created by Bosanek
To make the story short, I would like to swap the steering wheel between my old and new Jimny, as my old one has a leather steering wheel and I like that.
Both steering wheels are the same design (2006-2014), and have air bags.
Has anyone removed this type of steering wheel and can it be done without major considerations? I am mostly concerned about the air bag.
- Darthblaker7474
- Elite Member
- Thank you received: 37
8 years 6 months ago #192526
by Darthblaker7474
Replied by Darthblaker7474 on topic Removing the steering wheel
- Disconnect Battery, make sure steering is locked
- Undo two bolts under wheel
- Carefully remove airbag, making sure clock-spring does not spin too far (otherwise it will break)
- Remove nut, place back on so when you're removing the wheel it does not slap you in the face :woohoo:
- Try and remember how your wheel was placed on the wheel originally (mine's still wonky)
8 years 6 months ago - 8 years 6 months ago #192563
Replied by yakuza on topic Removing the steering wheel
I just did thisa week ago.
more or less like the description above:
disconnect battery
two torx screws on either sides of the steering wheel to loosen airbag
small yellow clip in the center of the center connection on the airbag to be lifted carefully, then unplug the wires.
mark center of the steering wheel with a pen or make a mark with something sharp.
loosen the nut, and wiggle the steering wheel until it stop against the nut.
reverse to get it back.
The leather wheel feels so much better!
disconnect battery
Last edit: 8 years 6 months ago by yakuza.
- MadsV
8 years 6 months ago #192570
by MadsV
Replied by MadsV on topic Removing the steering wheel
Any ideas on putting these newer wheels on older jimnys? Same airbag connections?
8 years 6 months ago #192592
2004 Jimny has more or less the same design as yours and a leather steering wheel I think. (Norwegian models)
8 years 5 months ago #192907
by Bosanek
Replied by Bosanek on topic Removing the steering wheel
Thank you very much for these guidelines.
What are the major risks during removal and installation, and in which steps?
I suppose if the airbag fires that I will need a new one at a horrendous price?
Can it happen that the ECU recognizes that the air bag had been fiddled with after everything is done and flash some fault light?
Time to create page: 0.101 seconds
