Replacement rear diff
  • andypandy
01 May 2018 12:03 #192320 by andypandy
Replacement rear diff was created by andypandy
Hi everyone, i'm a long time lurker with a 2005 VVT Jimny with an Auto gearbox.
It had a noisy diff when we bought it and its got gradually worse to the point now where there is significant backlash in the diff and more noise than before.
From the research i've done online it seems I need a 4.090 ratio diff and haven't had any luck finding one.
Does anyone know whereabouts I could source either a recon unit or failing that something secondhand?
I'm based in South Yorkshire.
Cheers,
Andy.
02 May 2018 06:48 #192326 by j999pre
Replied by j999pre on topic Replacement rear diff
Hi Andy. I have a vvt rear diff. It's a 4.3. I will check my and see what diffs vvt autos have. I thought they were the same as manuals. The non vvt auto is a 4.0909
Grey pick up Jimny
02 May 2018 07:48 - 02 May 2018 07:50 #192328 by yakuza
Replied by yakuza on topic Replacement rear diff
any Jimny diff from any auto Jimny should fit.
Last edit: 02 May 2018 07:50 by yakuza.
  • andypandy
02 May 2018 11:45 #192331 by andypandy
Replied by andypandy on topic Replacement rear diff
Thanks Guys, I had already figured out that I needed a 4.090 diff but can't seem to find one anywhere.
Might be going down the route of replacing the pinion bearings and see if that makes any difference.
02 May 2018 18:02 #192338 by Riccy
Replied by Riccy on topic Replacement rear diff
Might as well replace the diff sidegear bearings and wheel bearings while its in bits, wouldn't be that much extra work and gives peace of mind ;-)
you could use 4.3 diffs if you changed both of them to match and used some larger tyres. it would work well.
  • andypandy
11 May 2018 18:16 #192605 by andypandy
OK, so I ordered a bearing repair kit from www.rsmfg.co.uk but haven't heard anything from them. No answer on the mobile number provided on the website.
Does anyone know if they are still in business?
Time to create page: 0.113 seconds
