Leaking swivel and droning noise
18 Apr 2018 18:20 #191878
Replied by Riccy on topic Re:Leaking swivel and droning noise
Yep. Its axle oil. Kingpins and wheel bearings need done. Leak will be from the axle oil seal, depending on whats failed will affect the leak. I would guess wheel bearing gone as that sags and puts off centre pressure onto the oil seal creating the leak. Doesnt neccesarily make major noise or steering wobble when gone.
Wheel bearings need a special tool to get out and a press to remove/fit. I just removed the whole front hubs and took to a garage to get the bearings swapped. £10 in their hand and away i went
Dont overdo the grease as it will clog the vac lines in the hubs. Kingpin bearings & axle oil seal are easy on-the-driveway stuff with basic tools. The Wiki guide is brilliant help.
Bigjimny shop is a handy place to get spares
The following user(s) said Thank You: paradox1001
- paradox1001
20 Apr 2018 06:34 #191920
by paradox1001
Replied by paradox1001 on topic Re:Leaking swivel and droning noise
Thanks guys
20 Apr 2018 06:50 #191926
by kirkynut
Replied by kirkynut on topic Re:Leaking swivel and droning noise
If there's a droning noise it's the wheel bearing, which needs the use of a good press and the tool.
As has been said, you may as well change the King Pin bearings whilst it's that far apart.
Time to create page: 0.295 seconds
